by htg engineer »
Tue Feb 05, 2008 4:25 pm
Not familiar with this type of boiler, does it have a reset button ? could it have been switched on accidently when the system was drained and gone off on overheat ?
Does this boiler have a SIT gas valve, where the gas valve has three posiitons - Off, ignition and main flame ? is it in the correct position ?
Normally when the pilot is on, but it wont go to main flame - check there is power to the gas valve if there is - then it's a faulty solenoid.
