Post
by acsimpson »
Thu Nov 12, 2009 3:53 pm
Unless you think the showers wont be used at the same time as each other I wouldn't recommend running 2 showers from one combi boiler. If you do and someone is in the shower when the other is turned on there will be temperature flucuations.
You will get a similar effect if another hot tap is turned on in your house while someone is in the shower.
