Gurgling waste
Lawrence
Gurgling waste
by Lawrence » Sun Jan 13, 2008 11:54 am
Is there another way of solving a gurgling basin waste without fitting an air inlet valve?
I only have access to about a 200mm length of waste pipe (sloping at 1 in 40) that joins the trap to a vertical section of waste pipe which is concealed behind a wall. If the air inlet valve is the only / best way to resolve this problem can it be fitted on the 200mm section of pipe from the trap to the vertical pipe?
thanks
rosebery
by rosebery » Sun Jan 13, 2008 2:11 pm
Two options:
a. In line anti vac device.
b. Anti-syphon trap.
It is currently Mon Jan 20, 2025 12:50 am
