by toneyt »
Sat Jun 30, 2007 5:21 pm
this sounds like the water microswitch is sticking and/or the new diaphragm which we are assuming was fitted is worn /sticking too,if the tap goes off the water pressure should come off the diaphragm and break the microswitch and turn off the boiler,is there a demand light on the boiler? when the tap is on for hot water as you could observe this light to see if it goes off whan you shut down the tap,or listen to the boiler by hearing a click when you turn the tap on/off,try this with the boiler off so you can only hear the tap/switch noise,
Let me know how you get on!
T
