I am having problem with my combi boiler, {Halstead Ace High}. On opening the hot water tap, the boiler work fine but after 5-6 min running then burner goes off suddenly. I do not see any fault light on display /PCB either.
As the water turns cold and I turns the hot water tap off and on again. the boiler makessome checksbut fail to ignite. It appears that the pump is running. When the burner is off ; the ventilation fan is not working either. Moving the control button to RESET button in 50% cases would reignite the burner. It would appears that boiler is over heating and safety thermostat is cutting off yet ther is n't a lock out light as the Halsted fault finding diagram suggests.
Somebody in the trade suggestedto change the Air Pressure Switch. I have changed this APS but It has not solved the problem. after 10-15 minutes the boiler works again for anther 5-10 minutes.
I have changed the Hot water Thermister as well. This have not solved the mystery either.
Please suggest a solution for this misfiring of boiler.
thanks
