Hello all, my first post so please be gentle. My central heating system is an older gravity system (installed 1979ish) where the hot water temp is controlled by the boiler regulator. I should always have hot water but I don't have any hot water at the moment. The heating is fine. There is a one way valve coming out of the bottom connection of the immersion tank. Could this be blocked or stuck closed? It has a little plunger on the top which is free to move. I originally suspected air but this system should self bleed. (The expansion tank is full). I have spoken to a plumber acquaintance who said that there is no need for a one way valve on the immersion tank and he would remove it. Good idea or bad idea?
Thanks in advance for any help.
Mark
