by armytouch »
Sat Dec 20, 2008 8:14 am
Hi all,
I have recently returned home on leave after having boiler put in my house that i rent to my sister while i am stationed abroad,all details of boiler are in start of topic.I was wondering what all the pipeworks for.
I understand the Copper pipework been main water in,hot out.central heating in and return,then Gas pipe. However then you have a condensing pipe which apparently is to take away the excess acidic water reading from posts on this site,then theres another pipe which i thought was for the overflow, but sister has been told is for the build up of steam in the system and if not attached could cause the boiler to blow,we had to call the plumber back because this pipe had worked loose over the couple of months the boilers been installed,and now my sister is worried that if this pipe works loose again the boiler may blow the house up.Is there any safety systems in place to stop this from happening?
thanks
