Heavy Mirror and Plasterboard Fixing Didn’t Take
Maf123
by Maf123 » Fri Aug 10, 2018 10:21 am
Hi everyone
Looking for a bit help, we have a large mirror weights around 12kg and tried to hang it on the wal using self drilling wall fixing
Problem straight away was that the fixings just haven’t taken and when you try to screw into them end up turning and pushing right through the plaster board
Is there something else I should of used and what would be the best actions from here
Bit of a diy newb
Thanks in advance
KitchenGuy
Re: Heavy Mirror and Plasterboard Fixing Didn’t Take
by KitchenGuy » Sun Aug 12, 2018 9:11 pm
There are a number of different plasterboard fixing on the market but being honest I wouldn't trust any of them with 12KG. When we fix heavy things on a plasterboard wall we never use plasterboard fixings. The best way is to work out where the fittings go. Cut a slit into the plasterboard next to the position of the fittings, behind where the mirror goes if possible so it's not seen when the mirror is fixed. Then thread a baton as long as you can get it in behind the plasterboard and screw through the plasterboard to hold it in position. If you hit a stud you may have to put a baton in either side. Put back in position the piece of plasterboard you cut out, then fill any gaps or holes and sand back if required. You can now screw your mirror fittings through the plasterboard and into the baton. The baton will distribute the weight. It sounds more difficult than it it is but is very effective.
It is currently Sun Dec 01, 2024 3:56 am
