Height of concealed cisterrn to the top of the flush pipe?
ArrowSJS
by ArrowSJS » Wed Aug 27, 2025 10:18 am
Is there a recommended minimum height for base of a concealed cisterrn to the top of the flush pipe where it enters the toilet pan?
I have installed a Skylo concealed cistern. Have set the levels to the recommended heights in the installation manual. Finding that I am often needing two full flushes for an Ideal Standard Space Saver Toilet bowl.
This is actually not much different from the previous cistern.
The base of the cistern is 10cm above the top of the flush pipe.
I am wondering whether raising the height of the cistern would improve the efficiency of the flush.
Re: Height of concealed cisterrn to the top of the flush pipe?
by stoneyboy » Mon Sep 01, 2025 9:40 pm
Hi arrowsjs
If you can increase the height difference to the maximum suggested of 350mm this will improve the flow.
If the pan is a used one and you live in a limescale area, try running a limescale remover through it.
Regards SB
It is currently Thu Oct 08, 2026 3:49 am
