Hot Water but No Heating After Inspection it's now Working?
Woody71
by Woody71 » Tue Dec 29, 2020 1:56 pm
Hello,
Yesterday put heating on but only got hot water. Hot water was working but heating was not. So placed the 3 way valve to manual to make do. Looked today, took apart the box containing the synchron motor and detached from the valve to check valve has not seized. Valve was easily moved with fingers so should be fine? Put it together again thinking it was a motor (synchron) fault and tried heating. The motor moved lever to middle and heating is on and working? Yesterday it didn't work but today it is? Can anyone suggest if/what I did that has now made it work? And if there is a potential fault somewhere.
Many Thanks,
Andy
Re: Hot Water but No Heating After Inspection it's now Working?
by stoneyboy » Thu Dec 31, 2020 9:35 pm
Hi woody7
Probably the synchron motor starting to fail, if it happens again try fitting a new motor.
Woody71
by Woody71 » Thu Jan 21, 2021 10:33 pm
Again this evening turned the heating on and no noise, no boiler firing up and synchron motor not moving? Tried hot water and boiler fired up, synchron motor working. The valve is easy moved as before.
Any ideas?
by ericmark » Fri Jan 22, 2021 4:27 pm
Micro switch sticking, but in real terms needs a new head.
