I believe the term is deadleg but in case I'm wrong ... I have a storage hot-water system and like it or not, a bathroom that is at the end of a considerable run of pipe, with the result that it takes a while for hot-water to come through first thing in the morning. I'd like a solution that unobtrusively bridges that gap.
I've been told that I need a return loop on the hot water pipe back to the hot-water cylinder together with a circulating pump that circulates hot water around this loop. OK, that means a new pipe-run which will be difficult to thread through the building -> expense and mess.
I'd like something that is more straightforward. From first principles, what I think I'd like is something along the lines of a small local hot water cylinder connected in-line with the hot-water pipe. The cylinder would have a modest wattage electric heater (it won't have to produce instantaneous hot-water) and will only have a slightly larger capacity than the deadleg storage (say ca 5 - 10litre). The total assembly could be small enough to tuck away under the bath. When a bathroom hot tap is opened, cold water from the deadleg displaces the hot from the local cylinder to the bathroom tap, until hot water arrives from the main storage, when by thermostatic valving it bypasses the local cylinder and flows direct to the tap leaving the local cylinder with cold/cool water that can be heated ready for the next time. An appropriate control system to switch the local cylinder heating on/off appropriate to the pattern of hot-water use would complete the picture.
Does anyone know of some such (or another) solution?
