Hi guys,
I've been having some work done to my kitchen. We've had a wall removed to make a big kitchen-diner area and had an RSJ inserted. On the wall that was removed there was a radiator. The work is not quite finished so at the moment it has been laid down on the floor until it is removed completley. The valve on the non-temperature side of the radiator has been closed.
The problem I have is that now I can't get hot water and when the heating is on, none of the other rad's heat up?!
What could be causing this??
I've checked and the boiler is on, it knows when i turn on a hot tap as the LED lights up for hot water.
Cheers for any help!
Simon
