I have a low pressure heating system (gas boiler with hot water cylinder, vents, etc) and even though I have switched off the central heating on the control panel for the summer, the radiators heat up when the hot water system is activated.
My immediate suspicion is the the solenoid switch that directs the flow of hot water to each system. Even if I set it to "manual", it still heats up the radiators.
Any suggestions most welcome
