Hot water
jk2000
Hot water
by jk2000 » Fri Nov 23, 2007 12:25 pm
What is the best way to introduce a brass, circulatory pump, with timer into a hot water system.
I want to avoid wasting water that's gone cold overnight in a dead leg pipework from the cylinder to the taps.
So for example, the timer activates at say 5am & by the time the fist person rises at 6am, there's hot water ready at all outlets.
My system is a conventional gas boiler with unvented, indirect cylinder.
Thanks,
Jk
peter the plumber
by peter the plumber » Sat Nov 24, 2007 1:45 pm
I think this can’t be done.
I can’t think of away to remove water from the tap tails without turning the taps on.
I would say this is an insulation problem, not a plumbing one.
It is currently Thu Dec 26, 2024 12:58 am
