by htg engineer »
Mon May 19, 2008 9:05 pm
"the tank or pump by tank screeches after about 5/10 minutes?"
so which is it ? the tank or the pump ???
A screeching noise is more likely to come from the pump, vent the pump as it'll probably be full of air after the syatem has been drained. Vent all radiators.
The system may also be airlocked, so the hot water might not heat, but you'd get a runbling or banging from the tank not screeching.
htg
