Hello folks, I have a conventional y plan open central heating system, I recently replaced an old condensing energysaver boiler with a worcester 24ri greenstar, the energysaver required a by-pass across the coil in the cylinder the worcester does not so this was closed my problem is whenever I turn the new boiler temp. up beyond the middle position, the water out of the taps is in the region of 70 degrees 'c' I bought an infra red temp. sensor, to measure the temp. on the outside of the cylinder when I take off the cyl. stat to measure the temp behind it, it is only some 30 'c', about the same temp. as the outgoing pipe on the top of the cylinder but the water temp. coming out of the taps is 70 'c' ! how can this be? turning the cyl. stat down to 50 'c' does not seem to achieve anything but then it would'nt would it! the recovery rate is certainly very good now I guess about 15 mins.can it be that the coils in the cylinder are so efficient that the temp. in the top of the cylinder is way above that of the temp. 2/3rds of the way down where the stat is, or could it be that there is a build up of calcium in the bottom of the cylinder preventing the actual temp of the water being transmitted to the cylinder wall?
I am at a loss, I would like to run the boiler at as hot a temp. as possible in this current weather for efficiency purposes but the water temp. is hot enough to burn you, should i entertain the possibility of opening the by-pass again?
I have always used a water treatment device which is hung in the cold water tank, does anyone have any feedback about these? so I woud'nt like to think there was excessive calcium build up. does anyone have any ideas? regards,
