Hot water too warm
Cha
Hot water too warm
by Cha » Sun Jan 31, 2010 5:17 pm
The temperature of my hot water is far too high for the safety of children
(probably about 80 - 85 deg.C)
My HW cylinder is gravity fed, indirectly heated.
What is the simplest method of controlling the temperaure of the hot water?
Any advice most welcome.
Thank you.
Cha
by stoneyboy » Sun Jan 31, 2010 10:22 pm
Cha,
If you do not have a thermostat on the hot water cylinder then turn down the thermostat on your boiler.
Cha
by Cha » Wed Feb 03, 2010 7:02 pm
Thanks, Stoneyboy.
But doing as you suggest, would make the radiators colder, as well.
What's involved in fitting some type of thermostatic valve to the HW cylinder?
Cha
plumbbob
by plumbbob » Wed Feb 03, 2010 11:18 pm
Stoneyboy is right as that is the only way to reduce the water temperature. The downside is it will make the radiators cooler too.
Adding a thermostat to a gravity system is not easy as it requires significant changes to both the electrics and plumbing. Cost may be a prohibitive factor.
