Hot Water Underfloor Heating - Does the Boiler or Manifold Deal With Temperature?
keithpeirce
by keithpeirce » Mon Oct 27, 2014 9:50 pm
Do I need a separate feed from the boiler for underfloor heating? I understand it works at a lower temperature. So how does that happen if it comes off the central heating circuit? Or does the manifold sort out the temperature? K
Re: Hot Water Underfloor Heating - Does the Boiler or Manifold Deal With Temperature?
by htg engineer » Mon Dec 22, 2014 10:41 am
The manifold should have a mixer valve with 3 ports, it'll circulate itself with it's own pump - mixing the return and flow to get the desired temperature.
https://www.google.co.uk/url?sa=i&rct=j ... 1263735933
