by htg engineer »
Thu May 24, 2007 9:55 pm
what thermostat wont switch the boiler off, the room thermostat or the boiler stat ? if radiators are heating up when only the hot water is selected, its a problem with the actuator, or 3 port valve. Remove the actuator and select water only, then heating only, make sure the valve turns, also check spindle on three port valve is free to move.
