Hi...Any hints please?
I have a Megaflow unvented heating system Model 140.
Hot water OK...Boiler works in kitchen. Thermostat 'clicks; when turned up to higher temperature in hallway and the control unit shows both hotwater and central heating as being on BUT I have no central heating to the house, up or downstairs.
I cannot locate anything that looks like a pump in the airing cupboard next to the Megaflow so have no idea if the it's the pump that is not circulating hotwater round the radiators or not as I'm led to believe that there is a variable flow switch on most central heating pumps which may have helped if turned up.
Made sure that all switches are in correct position and have run out of ideas.
Please help!...
Regards
Paul B
