I am planning to convert my part integral garage to living accomodation. I have the design underway and will be applying for building regs soon. The front 8ft of the garage protrudes form the front of the house. The walls at this point are solid 9inch walls with no cavity.
Is there any way that I can "dry line" these without including a cavity so as to keep as much room in the already rather narrow garage as possible. Obviously any suggested solution must comply with the building regs.
Can anyone help.
