by plumbbob »
Wed Apr 08, 2009 10:33 am
The proximity to the pump is really not relevant here except to consider the radiator may need to be carefully balanced so as not to rob the other rads of hot water.
Remember unless the water is gravity fed, the hot water and heating particularly through the pump share the same pipes so you may find the rad heats when the water only is on.
You don't mention whether you intend to tee off in front of or behind the pump, which way round the pump is or whether it is in the flow or return.
To answer the question directly, you can tee off at any point.
