How to dealt with water damaged floor Joist
Geo3892
by Geo3892 » Fri Dec 11, 2020 9:21 am
The above is a joist located below my bath, discovered when the ceiling below was removed.<br />There are no leaks at the momment so its obviously historical, any ideas on the best way to deal with this.
Re: How to dealt with water damaged floor Joist
by stoneyboy » Sat Dec 12, 2020 10:20 pm
Hi geo3892
Suggest you treat the joint with rot and insect killing liquid. Cut a hole in the masonry next to the joist and fit a new joist alongside the existing one bolted to it. You will need a good metre of sound timber on the old joist and should use toothed timber connectors between new and old. May be worth encasing the joist end in dpc before you make good the hole.
It is currently Mon Dec 30, 2024 5:23 pm
