How to test an AC/AC doorbell transformer?
brian_mk
Re: How to test an AC/AC doorbell transformer?
by brian_mk » Sat Aug 21, 2021 12:18 pm
You have two choices: Either open up the cases and try to diagnose and fix the problem yourself or return both supplies for a refund or replacement.
It could be something simple like a connector or soldered joint.
Opening up the cases may be difficult or impossible if they are glued.
It would also probably invalidate any guarantee.
I think I would return both supplies. Both Amazon and CPC are pretty good when it comes to returning items.
by Mr White » Sat Aug 21, 2021 4:38 pm
itm60 wrote: I have always been extremely careful about selecting the correct function on the multimeter
itm60 wrote: I'm connecting the output cables of the transformers directly to a multimeter, and setting the multimeter to AC/15V
But it is a 24v transformer?
itm60 wrote: In the past if I have set my multimeter to a lower range than the transformer is delivering the reading simply goes off the scale in the multimeter - it hasn't done any damage to the transformer. I have done this many times
Just because you always do something (wrong) does not mean it is correct.
There is nothing you can do other than replace them.
It is currently Sat Jan 25, 2025 2:03 am
