How to Unscrew Sink Drain?
marcosscriven
Post by marcosscriven » Tue Sep 04, 2018 1:46 pm
Sink drain is full of detritus.
Managed to unscrew u-bend, but as I rotate underneath sink the whole drain cover rotates. There’s what looks like something for a very wide screwdriver to stop that (for which only a chisel is wide enough), but it won’t undo.
Any ideas please?
KitchenGuy
Re: How to Unscrew Sink Drain?
Post by KitchenGuy » Sat Sep 08, 2018 1:14 am
That's not unusual for it to do that, even when installing them. Try putting two screwdrivers into the waste outlet sink side in different hole sections and hold the two screwdrivers as you unscrew the trap. This should lock the waste while you undo it.
It is currently Thu Jun 25, 2026 1:32 pm
