I have a 17 year old Ideal W2000 Boiler which has worked great up until 2 months ago, first of all the heating would not work immediately [the rads would get hot 20 mins after the heating button was pressed] then the heating stopped working all together, the water however was heating up fine, then the water started to only get warm and now the boiler will only stay on for a matter of minutes before shutting down. I have installed a new Honeywell V4073A motor valve, fitted a new termastat and checked that the pump is turning when heating turned on [the pump does appear to be getting very hot].
It has got to the point where the boiler will fire up only when I press the hot water button and it will only stay on for 5 mins max. Can you help?
Many thanks
