imersion tank
charlotte77
imersion tank
by charlotte77 » Fri Jun 11, 2010 1:59 am
Can I add a second element to my hot water tank? The element at the top only heats top of tank and doesnt give me enough hot water!! Help!!!
by stoneyboy » Fri Jun 11, 2010 9:09 pm
charlotte77,
"Can I add a second element to my hot water tank?" NO Unless it has a boss already fitted which is unused.
Try replacing the existing element with a longer one.
charlotte77
by charlotte77 » Tue Jun 15, 2010 5:14 am
Thanks for reply. Do you know what is the longest element I can get?
by stoneyboy » Sat Jun 19, 2010 3:32 pm
charlotte77,
Immersion heater elements come in a number of lengths, the ones you will usually find are 11, 27 and 36 inches. The 11 is usually fitted in horizontal bosses on the cylinder; you will have to measure the height of your cylinder (flange to base) if you have vertical mounted heater an take off 6" to determine the maximum length of heater that can be fitted.
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Thu Jul 22, 2010 9:40 pm
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
It is currently Sat Jan 25, 2025 5:29 pm
