Immersion heaters keep cutting out
scheissefuergehirn
Re: Immersion heaters keep cutting out
by scheissefuergehirn » Fri Nov 04, 2011 10:16 am
I had this problem too. Mine kept cutting out because the central heating heated the water in the tank to a point that brought in the safety cut out in the thermostat. I fitted a thermostatic valve to the pipe between the boiler and the tank to cure this.
It is currently Fri Jul 24, 2026 4:13 pm
