I would like some information about a Baxi Bermuda 572 Back boiler. The problem is the main gas to boiler does not come on. Having had someone check it out it would seem the problem is the gas solenoid. There is a supply to it but there is no continuity through the coil? I have aquired a complete boiler and fire from ebay which I thought was lucky as the this model boiler has been obsolete for a long time. The boiler/fire from ebay has not been fired/installed but on checking the solenoid there is no reading across the coil. Either we have missed the diagnosis with the solenoid or I have been stupid/unlucky that the other boiler has also got a defunct solenoid. As the alternative in replacing the back boiler with a new system/combi boiler is going to be pretty expensive I am trying to see if the back boiler can be given a stay of execution.
Any information or advice would be most appreciated.
Mike
