is it the pump
6 posts   •   Page 1 of 1
r1mad
is it the pump
by r1mad » Tue Feb 19, 2008 10:16 am
hi radiators upstairs are warm not red hot though and down stairs are cooler or cold the pump sounds like its running but if memory serve s me it is not as noisy could it be the pump is slowing down so it doesnt have the power to feed all
thanx
r1mad
umm
by r1mad » Tue Feb 19, 2008 3:52 pm
came in tonite and the radiators that were cold this am were now hot and 1 upstairs was cold so bled them all and everything is hot could it just have been an air lock as quite a bit of air came out
r1mad
by r1mad » Tue Feb 19, 2008 6:46 pm
i know sounds like a comedy sketch but after a while turned off heating and on again now the down stairs are cold again and the upstairs are hot any ideas
by htg engineer » Tue Feb 19, 2008 7:59 pm
sounds like an intermittent fault with pump - the impeller may be loose or could be getting stuck - replace pump and all should be fine.
r1mad
by r1mad » Thu Feb 21, 2008 7:59 am
fitted new pump exactly the same as come off but still have problem of that if hw and ch are on together a few of downstairs radiators are cool or cold but if i turn ch off all rads get hot so ?
r1mad
by r1mad » Thu Feb 21, 2008 8:00 am
