Post
by Zacccc »
Wed Nov 12, 2014 4:35 pm
Trying to feed 8mm pipe through a hole I'd drilled in the floorboard I managed to get a slight kink in the pipe in spite of using a 8mm bender spring - although the pipe isn't fully kinked. It was already linked to the new radiator. Do I need to take it off the radiator and try again with a new length of pipe or will the water supply still be ok through the slight kink?
