Just moved to a grade listed property and we noticed a leak coming from around this pipe. Obviously it seems obvious that the crack in the mortar is most likely causing the leak but I am also not convinced of how they did the flashing on the side. Surely it should have been lead flashing instead of all mortar over the membrane, no?
What would be the best way to fix this without redoing it all?
