Post
by landau1945 »
Tue Aug 26, 2008 8:11 am
[quote="landau1945"][quote="htg engineer"]In the morning the boiler will be used more, for washing and showering etc. As it only seems to leak when in use it points towards the condensate discharge that is leaking, either the trap or pipework.
If it was anything else I would expect to see water all of the times, as the rest of the boiler is always full of water. Whereas the condensate part of the boiler, is only full when the boiler is in use.
The condensate trap is at the bottom, back, left of boiler.
htg[/quote]
Thanks HTG Eng.-I've got the Corgi man coming tomorrow.I suppose I could drain and clear it myself but why get in to any problems when I pay for breakdown insurance.I left a cloth under the boiler overnight and after the boiler switched on at 6.30 am when I examined at 8am the left hand side only,of the cloth was damp/wet.This is the side that the trap is on.
Thank you for your advice and confirmation of my thoughts,which will help when the engineer comes.Just an aside -shouldn't condensate traps be part of the annual service.?Not on mine by the way.[/quote]
Well Corgi man came.Nothing wrong with condensate trap he says.Not cracked,no sludge,etc.If it was overflowing then the dry sensors would cut in and stop the boiler he says.No other leakage from heat exchanger etc.Could be blockage in condensate pipe,but he can't do this so will send in plumber.Hells bells I see a long saga here going round in circles .Good job I'm semi retired and can hang around a bit waiting!!
Any more ideas HTG Eng.?Thanks
