hie all,
need some suggestions. since the weather has improved i have turned off the central heating. when the boiler comes on to heat the water i can hear noises through the pipes that sound as if there is a leak. it doesn't matter which part of the house i am in the noise is consistant but when the boiler is turned off there is no noise what-so-ever.
