Leaking Y Splitter Under sink
xsamx1987
by xsamx1987 » Sat Oct 13, 2018 8:22 pm
Hello all ok so I fitted a new brass y splitter I will provide link to the exact one i bought
I have used plumbers tape and all new washers
But for some reason I have a slow leak from where it connects on to the main pipe
Is there a special way I should fit it with my hand or a tool?
https://www.amazon.co.uk/Splitter-Manifold-Washing-Machine-Connector/dp/B01LVYWN8A/ref=cm_cr_arp_d_product_top?ie=UTF8
KitchenGuy
Re: Leaking Y Splitter Under sink
by KitchenGuy » Sat Oct 13, 2018 11:56 pm
Don't use plumber's tape, it is not appropriate for this sort of fitting. The knurled end has a rubber washer in it which makes the seal. Putting tape on it would most likely cause it to tighten up before the seal is engaged. Make sure the rubber washer is in place, then just hand tighten, put some grips on the knurled ring and just nip it up, approx a quarter turn or even less. This sort of fitting does not like being over tightened or it will damage the seal.
collectors
by collectors » Sun Oct 14, 2018 2:51 pm
Looking at the fitting i would of thought some good washers & pipe grip's should be enough. This is assuming you are not fitting any sort of adaptors.
xsamx1987
by xsamx1987 » Tue Oct 16, 2018 12:15 am
Thanks Guys now seems to be water tight :)
It is currently Sun Jan 05, 2025 4:17 pm
