lighting circuit problem
jock
by jock » Thu Jun 28, 2007 11:11 am
i have no power to my kitchen lighting curcuit but the circuit breaker has not tripped.this happened after the heavy rain
by sparx » Thu Jun 28, 2007 9:46 pm
Hi JOCK,
several possibilities, if all other lights on is kitchen an extension to original house? reason being that sometimes lights in extensions fed from power circuit via fused spur tucked away some where you may not even have noticed it! local fuse could have blown in spur, otherwise more info on house layout would be helpful,
regards SPARX
BLAKEY1963
Re: lighting circuit problem
by BLAKEY1963 » Thu Jun 28, 2007 10:23 pm
[quote="jock"]i have no power to my kitchen lighting curcuit but the circuit breaker has not tripped.this happened after the heavy rain[/quote]
HELLO JOCK
WOULD U B THE SAME PERSON WHO HAD PROBLEMS WITH SOCKETS TRIPPING MCB AND RCD. MESSAGE WAS POSTED ON 15TH JUNE 2007 ?????????????
BLAKEY1963
dalling73
by dalling73 » Fri Jun 29, 2007 6:54 pm
i need 2 run a lighting feed for 2 lights in my attic,whats the easiest and safest way 2 do this without going back 2 fuse board.thanks
It is currently Tue Jan 07, 2025 12:46 pm
