Loft Conversion options
kmjewsbury
by kmjewsbury » Mon Apr 02, 2007 11:17 am
I could do with some advice about a possilbe loft conversion.
The loft is 7m by 10.65m and is 3.35m to the apex. The roof is held up using 4 long rafters these are held in place by 2 'A' Frames. The 'A' Frames split the Loft into 3 sections. The 'A' Frames are well of the floor and 1/3 of the floor has full sized floor joists.
What options do I have.
I have attached a layout drawing and a picture of the 'A' frame at the web site below.
Karl
thedoctor
by thedoctor » Mon Apr 23, 2007 5:42 pm
See our project on loft conversions
markbath
by markbath » Tue Apr 24, 2007 1:56 pm
I have a large bungalow with a very shallow roof.
If I wanted to convert the loft space would I have to replace the roof / build a second floor or would it be possible to fit large dormer style windows.
What would the minimum height of the apex be in order to have a viable space ?
Mark
thedoctor
by thedoctor » Mon May 07, 2007 8:03 am
Its not really possible to tell if dormers would be enough without drawings etc Mark and the regs state a minimum of 2m head height as you come up the stairs into the loft space but there are a lot more regulations involved in a loft conversion that this. Go to our projects section and have a look at the loft conversion project where you will get detailed advice.
It is currently Sun May 25, 2025 6:28 am
