by htg engineer »
Sat Sep 06, 2008 8:26 pm
Not that simple, obviously it depends on the heat input of the boiler, the size of the house, size of radiators, lengths of pipe runs etc etc.
It's all down to personal preference, setting boiler stat to max is probably too hot for most houses.
Balance the radiators so that there's 11 degrees C temperature difference between the flow and return, by closing lockshield valves slightly. If the flow is 50 degrees and the return is 49 degrees there's only 1 degree C being transferred to the room.
Use TRV's - again personal preference. I like a cool bedroom and warm livng and bathroom. I have TRV's in bedrooms set to 2 or 3 and set to max in living room, and I don't have TRV in bathroom.
If you have to add cold water to wash dishes or bathe - the water is too hot. Why not turn it down so it's exactly the right temperature for your needs.
htg
