Motorised Valve
alanwest
Motorised Valve
by alanwest » Thu Nov 01, 2007 8:16 pm
The motorised valve on my central heating keeps ticking and causing electrical interference on my TV. I have replaced the motor but this has not stopped the problem. When the valve is activated the motor keeps oscilating slightly. I can stop the ticking by manually locking the valve open.
The Heating Doctor
by The Heating Doctor » Thu Nov 01, 2007 11:48 pm
not come across this for years, you can get an electrical filter from the likes of Mapplins or RS. components
marrtin
by marrtin » Fri Nov 02, 2007 1:48 am
Are you sure it's wired correctly? Can't see why the motor should oscillate. It should open and stay open. Is it a 2 port or 3 port valve?
alanwest
by alanwest » Fri Nov 02, 2007 5:34 pm
Thanks for tips. Problem solved. The relay switch inside the three port valve was worn, thus not switching positively. Hence the oscilating (relay cuitting in and out). Had to invest in new Power Head. Hope this helps someone else.
