Hi, need help with the position of the motorised valve which will be connected to the cylinder stat. Boiler supplies heat for rads and hot water which is fine but want to stop the water from overheating hence the stat.
I can access the pipework at A and B but don't know which is the best side to fit it on or even if it makes any difference.
Any help much appreciated, thanks.
