New Apartments Lift required?
Fox101
Post by Fox101 » Mon Aug 06, 2012 4:48 pm
Hi all,
This is my first post on here although I've found the info on here invaluable in the past. Basically I have a friend who has a plot of land that currently houses some old lock ups/storage units. He is wanting to look at potentially putting apartments on the plot (its in not too bad a location). At this stage trying to avoid architects fees and produce some sketches as to how many units could fit on the site to see if its worth taking forward.
I am semi-familiar with building regs, but regarding apartments at what point/building height is it required that an elevator needs to be provided?
Re: New Apartments Lift required?
Post by welsh brickie » Tue Aug 07, 2012 6:49 am
an elevator does not need to be required at any height its there for convience,In the event of a fire the elevators power is cut,as fire is the main concern with apartment blocks.
Fox101
Post by Fox101 » Tue Aug 07, 2012 7:44 am
welsh brickie wrote:an elevator does not need to be required at any height its there for convience,In the event of a fire the elevators power is cut,as fire is the main concern with apartment blocks.
Welsh,
Many thanks I suspected as much, as after going through all the Building regs Documents the only reference I could find to providing one was regarding disabled access, although providing one was not required as a stipulation.
