New Radiator
Barry Bunsen
New Radiator
by Barry Bunsen » Mon Oct 13, 2008 8:10 am
I need to fit a new radiator to an existing system which should be straightforward. However I have 3 questions.
1. The flow is 22mm and the return 15mm at the point most convenient to tee into - about 4 meters from the combi boiler. Can I come off both with 15mm pipe?
2. When complete do I need to flush the complete system or would a single radiator not create sufficient gunge to make that necessary.
3. Not really a question. Any advice about adding the inhibitor please.
TheDoctor4
by TheDoctor4 » Mon Oct 13, 2008 10:11 am
Have you had a look at the DIY Projects section at all as there are numerous projects relating to Central Heating that may provide you with the information you require: https://www.diydoctor.org.uk/projects.htm
Regards
It is currently Sat Jan 25, 2025 3:47 pm
