No Hot Water After Re-Pressurising Boiler but Cold Water Fine
CClarke89
by CClarke89 » Sun Mar 18, 2018 7:45 pm
Hi All,
I had to re-pressurise my boiler today, and since then I havent had any hot water.
The cold water taps work fine, as does the heating but the hot taps and the shower have not water flowing from them. I have tried reseting the boiler and, changing the dial from water/heating to just hat water but nothing has worked.
Not quite sure what I could have done to cause this, and I can't really find any useful info online, so I was hoping you guys might be able to help.
For ref I have a Vokera compact HE combi boiler and I'll attach a pic of the pipes under the boiler.
if you need any more info let me know.
Thanks.
sheffarc
Re: No Hot Water After Re-Pressurising Boiler but Cold Water Fine
by sheffarc » Sun Mar 18, 2018 10:59 pm
I had a similar once and it was the gas valve lever next to the gas meter that had been moved to half way off. This gave enough to heat the central heating but not the hot water.
CClarke89
by CClarke89 » Mon Mar 19, 2018 7:01 pm
sheffarc wrote:Hi
Thanks for the suggestion, but that doesn't seem to be the problem. The gas valve is still in the open position.
sheffarc
by sheffarc » Mon Mar 19, 2018 10:28 pm
Hi sorry that's not it, is the biker turned up high enough for the cold weather.
Do you have full pressure on the hot tap
It is currently Sat Jan 11, 2025 6:12 am
