Hi , I've removed 2 radiators for redecorating in the kitchen, 1 of them I've fixed stop ends to the pipes as I won't be replacing it. I've also disconnected the sink and put stop ends on those existing pipe's.
I've reconnected the sink the other end of the kitchen to existing hot and cold water pipes which were the same ones feeding the sink taps in the origional position.
The combi fires up no problem when I turn the hot tap BUT....
I think I've drained the combi boiler as the water flows out of the hot water tap but it isn't hot and the PRESSURE GAUGE is 0.
Am I ment to refill it and how ??
