today the central heating system stopped working, and the transfo overload protection for the "fire plug" trips after every failed attempt.
What is the likelyhood the oil pump is blocked? When I checked the fuel filter, it was all full of black gunk, the oil that came out was black as coffee... Not that the filter would do any good, it's only for very big paarticles (about 1mm)
checked for fuel between the pump and the injector, but no flow when the burner tries to fire up.
Is it worth a try to remove the pump in the morning and give it a clean?
