I'm just installing a electromax electric flow boiler and dwh unit and want to know what size copper pipe to use for the heating system the the outlets from the unit are 22mm can i downsize to 15mm immediately as i don't fancy notching 22mm pipes in every where the unit is housed upstairs and there are a 3 radiators upstairs and three downstairs the unit is 9kw output and the radiators are a total of 6kw. Also i'm replacing my immersion heater with this unit and currently the cold water mains supply to the immersion cupboard is only 15mm is this going to be a problem.
