i recently had an old back boiler replaced by a combi. there was a 28mm pipe between the backboiler and the hot water cylinder and the pipes from the cylinder to the rads 15mm
when the combi was installed the plumber left the 28mm pipe in the middle of the system and reduced it at both ends to 15mm to join to the existing 15mm pipes.
is this arrangement likely to affect the performance of the system and should the 28mm have been replaced by a 15mm to match the rest of the system?
any thoughts or suggestions greatly appreciated.
