pipes rumbling
lindahayes
pipes rumbling
by lindahayes » Tue May 19, 2009 4:01 pm
Hi new to forum,hope you can help plz.No matter when on or off the pipes constantly rumble and it sounds daft but also like a tic niose.What could this be it happens even during the nite
by stoneyboy » Tue May 19, 2009 9:58 pm
lindahayes,
Have you got the hot water on continuously. If not find your main switch for the heating system and turn this off and see what happens.
lindahayes
by lindahayes » Wed May 20, 2009 3:16 pm
Thanks for reply,but done all that any other suggestions.
Ta linda
by htg engineer » Wed May 20, 2009 8:05 pm
The pipes will click and move when heating and cooling, if the boiler is off and all pipes are cool or room temperature - there'll be no noise from the system ? correct ?
Probably nothing to worry about. If it really does bother you, you could lag and clip pipes to minimise the pipes rubbing against each other and joists etc
htg
lindahayes
by lindahayes » Thu May 21, 2009 3:21 pm
Thanks for reply?we will try and hopefully that would do it
linda
