by wayne 78 »
Wed Feb 06, 2008 6:54 pm
hello all i av just run new pipework for my central heating adding 3 new rads in my cellar i hav done 98% of the piping in copper and end feed but run out of copper but a freind of mine had a bit of spare plastic piping left wat he used for his bathroom its from flo plast so i used 2 plastic elbows and one plastic coupling and about 10" of pipe on each flow + return i filled system up n everything is fine wat im unsure of is i seen the pipe i used in my screwfix book and it says the pipe is for all hot + cold water + heating but on the push fit fittings it just says suitable for cold +hot water systems so will the fittings be ok to use on the heating curcuit or are they uncompatable sorry if its a stupid question but need to put my mind at ease thanx
