plumbing
ldowney
plumbing
by ldowney » Wed Apr 01, 2009 10:48 pm
hi ,please can so one tell me do i need to fit a flange on top of my water cylinder if i want to take a feed for my new shower valve or do i only fit one off them if i am fitting a pump . :?:
by stoneyboy » Thu Apr 02, 2009 9:25 pm
ldowney,
Try it without - you can always add a flange at a later date.
rosebery
by rosebery » Thu Apr 02, 2009 10:48 pm
Pumped or not you should have hot and cold supplies for the shower that sre independent of the rest of the DHW system.
plumbbob
by plumbbob » Sun Apr 05, 2009 12:51 am
You don't usually need a flange unless the header tank is low down. Usually, if it is the loft, you should be fine - with or without a pump.
It is currently Thu Apr 17, 2025 10:57 pm
